Wiring Question
allen02
06-22-2004 18:12:02
I have been helping to restore an 8n to good running condition. I needed a few helpful suggestions on the how to run the wiring for the tail light. I figured you guys could help. Thanks.
souNdguy
06-23-2004 11:29:15
 Re: Wiring Question in reply to allen02, 06-22-2004 18:12:02
On my 8n, I used a piece of that flexible metal conduit, and installed a switch in my dash next to the headlight switch.. and ran the conduit just up under the dash. It clears the steering arms and the clutch pedal, and runs under the running board, and along the brake linkage then up to the fender bracket, etc..
On my 2n I did the same with spagetti loom cable.
Not oem setups.. but worked for me.
Soundguy
allen02
06-22-2004 20:12:34
I am looking for the best route to run the wiring for the tail light to keep it out of the way of moving parts.
Scott
06-22-2004 20:11:29
There are diagrams in some of the parts books that show the factory routing, and the associated clips and brackets used. If you don't have one of the books, you can get the general idea by going to Dennis Carpenter's site and viewing the catalog page 83 (page 91 in the PDF file).
If you're not concerned with the originality of it, you can basically run it however you want.
I ran the wires in 5/16" copper tubing from the dash back to the fender, made a couple of brackets to hold the tubing here and there, then painter it all the same color as the tractor.
craig
06-22-2004 19:55:36
I'm not sure what your question is. I would just wire the rear light to the front lights. 8ns rock!!! Too bad I'm selling mine. Good luck with the restoration. Craig
