Seal question on rear axle
Alex Dula
06-25-2004 16:02:00
I finally got to clean off the left rear axle on the 52 8N an there are two small gaskets that I am not sure of the number. The first came off the axle when I took the drum off (I think ?) and the other one was next to the bearing on the wheel side of the bearing when I was cleaning off the bearing. They appear to be felt or cork and fit over the axle and are not very thick or high (about 1/8" or so).
The parts book and I & T manual are hard to understand in the seal areana. The serial no. of the 8N is 444857 if that helps.
I have looked at past posts and I am still confused about the seal arrangement.
Thanks,
Alex
Hobo, NC
06-25-2004 17:44:57
 Re: Seal question on rear axle in reply to Alex Dula, 06-25-2004 16:02:00
Just use silicon in place of the gaskets
