Order Ford 9N Parts Online
9N oil in water
Aaron SEIA
06-27-2004 13:19:19
A friend of mine has the chance to buy a 9N with several implements for a pretty reasonable price. However, they said that it's putting oil in the water. Didn't say how bad, and we can't look at it till Tuesday or Wed. Is this a common occurance on 9N's? I'm not a Ford guy myself, but can fix most anything. I would hope it's just a bad headgasket, but am wanting a more learned opinion. What other things should I look for when we go back? Just worried that the oil thing could be a cracked block or head. Any thoughts?
Aaron SEIA
hig
06-28-2004 03:51:08
 Re: 9N oil in water in reply to Aaron SEIA, 06-27-2004 13:19:19
cracked block near o.p.r.v
Dell (WA)
06-27-2004 17:38:01
Arron..... ....most "oily sheen" floating on top yer radiator water is "combustion by-products" forcing their way past a leaky headgasket. NO BIG THING. Blott-itt up with paper towels. Iff'n it bothers ya, replace yer headgaskett, $20 cheap..... ...Dell
souNdguy
06-27-2004 16:31:08
Are you really pumping oil into the radiator.. or is there merely a skim of combustion by-products in the radiator. A bad headgasket WILL do that.. ( combustion byproducts.. etc.. in the water. ).. Sometimes you also get some oil/water emulsion in the crankcase as well.
Pull the radiator cap and start the engine.. if you get bubbles that is a sure sigen of compression loss.. possibly headgasket if you are lucky..., though there certaintly are other causes.
Soundguy
Ramon
06-27-2004 16:08:16
No easy outs on this one. On the "N" tractors the oil does not go up through the head or the head gasket.
