Solidstate replacement for 6 volt Echlin regulator
RayV
06-28-2004 20:22:16
I'm pretty sure I read about a supplier on this forum. Anyone recall the link? I have a TO-30 but I believe the regulator would be the same as on the N's. Thanks
Dell (WA)
06-29-2004 12:10:28
 Re: Solidstate replacement for 6 volt Echlin regul in reply to RayV, 06-28-2004 20:22:16
Ray..... ....do a google search on "echlin voltage regulator" (I did) and you'll probably find your answer..... ...respectfully, Dell
who found out NAPA is part of Echlin Ind.
Jim Cox
06-29-2004 11:21:44
you could go to most any AGCO/Allis or Case/IH dealer for this VREG. 6V Pos gnd A circuit, real common, but I wouldn't use a FORD VREG on it, I'd go with a 'fits Delco'.
Jim Cox
Generator Guy
souNdguy
06-29-2004 11:52:00
 Re: Re: Solidstate replacement for 6 volt Echlin r in reply to Jim Cox, 06-29-2004 11:21:44
What changes did the delco gennies do that changes the vreg..? ( being curious here.. ) different field coil? therefore different resistance and calibration for the vibrating contact?
Soundguy
souNdguy
06-29-2004 06:13:11
I saw an add a while back about a solid state 2 terminal cutout for the 1 wire gennies.. and also a solid state 2 terminal cutout/regulator, again.. for the 1 wire gennies. Is that what you have? or do you have a 3 wire genny?
Do you not like the standard vibrating contact regulators?
Soundguy
RayV
06-29-2004 13:39:16
 Re: Re: Solidstate replacement for 6 volt Echlin r in reply to souNdguy, 06-29-2004 06:13:11
1953 Ferguson TO-30 everything restored as origional. (except color, after all the work I just had to add some red) Delco-Remy third brush, two wire (A&F)generator. New wiring harness. I have replaced the regulator twice in last 5 years. Same service history and problem symtoms for both. They work great about 2 years, then stop enabling a charge. When battery starts getting weak, I can tap on side of regulator and the amp meter starts showing a charge....until battery charged up. A charge cycle will not begin unless I tap the regulator. I took the first unit apart and drew some 600 grit sandpaper between the contacts. That would cause regulator to resume normal function, but only for a month or so. Became too much trouble to repair so I purchased a replacement. NAPA $61.51. Now two years later having same symptom as before and can repair temporarly in same way. I just expected a regulator to last at least 10-15 years. Any advice welcome.
souNdguy
06-30-2004 05:20:15
 Re: Re: Re: Solidstate replacement for 6 volt Echl in reply to RayV, 06-29-2004 13:39:16
I would also expect a regulator to last longer than that. The one on my 66 IH cub looks OEM. And my NAA has a very old alternator with v-reg... housing is rusty.. etc..
Are you mounting it in a spot that it gets wet alot.. or bounced around?
Even though that sandpaper 'brings it back to life' it is damaging the contacts too. Try a points hone or file on it instead. Even a piece of brown paper grocery sack.. or as one member suggested.. a dollar bill. It leaves less striations on the contact area of the points.
Soundguy
