.... and then there's the other 10%
Russell_D.S.TX
06-30-2004 15:24:27
I was having a common problem: my '49 8N would run fine, but would sputter and stall under a load.
It would start right back up, but then stall as soon as I released the clutch. I read in several forums that 90% of all fuel problems are electrical.
Here's what I did:
1) replaced the coil -- no difference
2) rebuilt the distributor (points, rotor, condenser, gaskets) -- not much difference
3) adjusted timing (by trial and error) -- big difference, but in the wrong area. This made the engine purr like a kitten, but didn't solve the stalling problem
4) replaced the ignition switch - per Dell -- no difference
5) rebuilt the carb (with the $40 kit) -- big difference, but under a really heavy load it would still stall.
6) re-bent the fuel line -- SOLVED!!!!
The line had an "S" shape in a vertical plane - down from the tank, then up, then back down to the carb. I moved the "up" part of the "S" to the horizontal plane, so the gas never has to travel against gravity.
Now I can bush hog 2 acres (about 2 hours) of very thick grass without so much as a hickup.
Fast Ed Ohio
06-30-2004 23:39:59
 Re: .... and then there's the other 10% in reply to Russell_D.S.TX, 06-30-2004 15:24:27
Yea, most good tractor mechanics would see your problem from the get go with one look, Ahh ,one picture is worth a thousand words ,sometimes common sense rules , gravity fed system going aginst gravity , dont blame Dell or others on this board, they are only going by what they are told, most N problems are electrical, 10% fuel related .
NvanDeusen
06-30-2004 16:52:51
Congrats Partner. Have Fun out there
