axle housings and distributor cap
Alex Smith
07-01-2004 08:58:07
I have a 48 8n and was wondering if I could swap the rear axle housings from a 50,51,52 8n so I could use the double axle seals. I'm also having trouble with my distributor cap being broken on the lower right ear plug wire inlet. Is there a spacer that could be worn allowing this or would it be the axle? Any help would be appreciated. Thanks, Alex Smith
Dave OH
07-01-2004 21:31:04
 Re: axle housings and distributor cap in reply to Alex Smith, 07-01-2004 08:58:07
As "Jeb2N" said the King Pin and Bushing should be replaced. A common problem lately seems to be finding a good matched King Pin and Bushing. Many of the Bushings I.D. are oversized and the King Pin is a very loose fit. Probably "China made bushings", so check it out when buying.
Dave OH
souNdguy
07-01-2004 11:05:33
I think you would have to swap out the axels as well as the trumpets.
Soundguy
Jeb2N
07-01-2004 09:26:21
Don't know about the axle trumpets but your distributor problem is related to a worn out king pin on the front axle.
