Order Ford 9N Parts Online
9N CONTROL VALVE PROBLEM
SPEEDWAY SQUARE
07-01-2004 21:34:14
does the control arm fork set straight up & down or does it tilt back a little towards the rear??? the 3 pt stopped working figured it needed fluid changed, did that still didn't do the trick, drained new fluid opened the inspection covers, seen the control arms had worked thier way off the ball ends, just about got them back on when the small tip coming out of the control valve broke (not good), since it broke i decided to rebuild everything while it was down not making any money to save me from doing it later. now i can't figure out which way the control arm fork goes after taking it off for wear inspection, got all the parts just forgot which way it goes and my itshop manual is pretty worn out and can't see the pictures real well.
any help will be appreciated,
thanks in advance
SPEEDWAY
BROKEN ARROW,OK
Dell (WA)
07-01-2004 22:38:31
 Re: 9N CONTROL VALVE PROBLEM in reply to SPEEDWAY SQUARE BALING, 07-01-2004 21:34:14
Speedy..... ...yep, yer memory ain't completely failed (yet, grin). the tuning fork control valve arm has a slight rearward bend/slant..... ....HTH, Dell
