threads on axel
Robert
07-02-2004 12:26:44
What is the best way to clean up threads on the end of my axel on my 52 8N
I got new nuts but the one side seems to be rough and I do not want to force it on .
Bill
07-02-2004 14:55:20
 Re: threads on axel in reply to Robert, 07-02-2004 12:26:44
Robert,
You can use fine valve lapping compound.
Make sure the nut is started square. Apply a small amount to the axle and start the nut working it clockwise and counterclockwise it will clean the threads.
Be sure and clean the nut and axel when finished.
Steve(OR)
07-02-2004 13:32:09
If you can't get them cleaned up there is a lock nut that can be used for damaged threads for about $15.
Gaspump
07-02-2004 12:50:47
You can either purchase or borrow a thread file they usually will clean up rather nicely.
