Tractor out of storage
Rex from Indian
07-02-2004 20:07:03
If anyone can give me advise, I would greatly appreciate it. I bought a 8N (1950) and used it very little late last fall. Previous owner said I should drain the trany, rear end and hydo fluid incase it had water. I did it late last fall and let the tractor set outside all winter. I am going to put new fluid in this week. Should I take any percaution or look for anything in particular? Should fluid set in tractor for a few days before I use it?
Any help would be great.
Thanks
Rich, NJ
07-03-2004 06:23:28
 Re: Tractor out of storage in reply to Rex from Indiana, 07-02-2004 20:07:03
A word about those cheapsh** shifter boots. I bought one for my 8N and in two years it disintegrated! I now use an old boot from a car axle. they stand up to the weather much better. Rich
souNdguy
07-02-2004 21:01:29
I agree with Rob.. once you get the sumps clear of water.. fix the shifter boot. then keep oil in it at all times.. its a great rust preventative..
Soundguy
Rob
07-02-2004 20:18:02
I can't imagine why you can't fill it and use it. Make that shifter boot good because that's where the water gets in. You can get one at the local farm/ranch store. Double check the package against the tractor serial number/yr/model to get the proper boot. Soften it up in warm to hot water to make it install easier might be an idea.
You know empty tanks get condensation in the fall and winter. That sump might be tight enough but I don't know about that. I leave the oil in all year and I'd be afraid of condensation and rust if it was empty.
SPEEDWAY SQUARE BALING
07-02-2004 20:12:08
fill it up with 5 gals. of g1, start it up, work control lever several times real slow all the way up and all the way down, watch and make sure your arms are moving up and down, hook equip. up and go to town with it
SPEEDWAY BROKEN ARROW,OK
Rex from Indiana
07-03-2004 07:47:13
 Re: Re: Tractor out of storage in reply to SPEEDWAY SQUARE BALING, 07-02-2004 20:12:08
Hey, thanks for all of the good ideas.
Rex
