Timing Mark
Bruce (TX)
07-02-2004 21:41:09
I am putting my 8N overhauled engine back together.
When I got ready to line up the timing marks, I found the notch on the timing gear, but when I looked at the crank shaft gear there was no mark visible. I took sandpaper and sanded the crank shaft gear.
After sanding the gear, I found a 0 stamped in the middle of one of the teeth. Is this the timing mark to match with the notch in the timing gear?
Thanks for any help.
Bruce
Bob
07-02-2004 23:36:26
 Re: Timing Mark in reply to Bruce (TX), 07-02-2004 21:41:09
third party image
Notice the orientation of the crankshaft key when the timing marks are lined up, and (the following only applies to the front-mount distributor) also notice the orientation of the distributor drive slot.
