N need a thermostat?
Rob
07-06-2004 07:16:09
Guys talk about leaving out the thermostat out but I'm certain Ford didn't put any unnecesary parts on his tractor. Leaving out the thermostat is a bad idea that limits performance and robs hours from the life of the engine.
The engine must be at a constant operating temperature to properly adjust the carburator for peak performance. A constant operating temperature is maintained by the thermostat. No thermostat and the operating temperature varies away from peak performance depending on the the season and load.
A high, constant operating temperature boils away moisture and also prevents the accumulation of harmful combustion by-products in the crankcase and oil. Also, a good, clean breather cap will help keep the crankcase dry.
The engine needs a thermostat to provide consistant peak performance and the thermostat and breather cap helps prolong the life of the engine.
Dan
07-06-2004 12:43:06
 Re: N need a thermostat? in reply to Rob, 07-06-2004 07:16:09
Every N I have seen without a thermostat had lower compression cascading back to the dash. For example, my 48 8N had no thermostat and had a compression of 110/98/95/85. the cooler water from the radiator helped the front cylinder closest to the radiator, but hurt the other cylinders progressively worse as it moved away from the radiator. I would much rather have a solid compression of 95 across all cylinders than the above example.
Good luck,
Dan
Rob
07-06-2004 12:55:53
 Re: Re: N need a thermostat? in reply to Dan, 07-06-2004 12:43:06
I wondered about that. You know they figured all the clearances and sizes based on the normal operating temperature. Makes sense to keep the engine at a uniform temp.
Geo in SD
07-06-2004 07:58:07
Right on, Rob. Running without a thermostat is one of the best ways to reduce performance and shorten engine life.
Rob
07-06-2004 09:16:00
 Re: Re: N need a thermostat? in reply to Geo in SD, 07-06-2004 07:58:07
Hey George! That sounds like a 'worse way' to ME.
Just kidding, I know what you mean. I knew about the moisture and all forever but it just dawned on me about the carb adjustment. I was going over how to adjust the carb and I finally saw it.
Thanks.
