Order Ford 8N Parts Online
8N will not run
Roger
07-06-2004 08:44:49
My 8N (early model) starts easily but will not run. Will run one to five seconds after starting. Fuel feed appears is good to carb. Have cleaned the carb, all inside carb parts appears good. Have cleaned the oil bath air filter, it was plugged up but after cleaning and fresh oil no change about running after that. Any and all suggestions welcomed. Thank you
Ole Henry
07-06-2004 17:19:55
 Re: 8N will not run in reply to Roger, 07-06-2004 08:44:49
Roger, sounds like a bad condenser, or points burned or closed.
John A(Va)
souNdguy
07-06-2004 12:23:20
"""Fuel feed appears is good to carb. """
Appearing good isn't good enough to run an engine... Verify that it is good. Pull the plug on the bottom of the carb and see if it will pee a good solid pencil sized stream into a glass jar without tapering off. If it tapers off.. you have a fuel restriction. I fhtere is water or other gunk in the jar.. that could/is a problem as well.
Soundguy
Roger
07-06-2004 13:00:38
 Re: Re: 8N will not run in reply to souNdguy, 07-06-2004 12:23:20
Thank you, I give it the pee test.
Steve IA
07-06-2004 09:13:06
During the 1 - 5 secs it runs are you pressing the starter button, perchance? If it only runs when the button is pushed, something is wired wrong. Steve 8N 169302
Roger
07-06-2004 09:33:12
 Re: Re: 8N will not run in reply to Steve IA, 07-06-2004 09:13:06
Steve, the starter button is off during the short run periods. thank you.
