Rich..... ...thatza pretty good diagram. That'll help a whole lot in gittin' yer squarecan frontmount 12 volt conversion running. 1st off) ignition coil. gotta know/make decision wheather to use the OEM 6 volt squarecan coil, or the modern 12 volt squarecan coil. Unfortunately, the coils are NOT MARKED except on the box. Since you've burned out one coil according to your diagram, that implys its an OEM 6 volt coil. The OEM 6 volt coil always REQUIRES the "infamous ballast resistor" mounted on the backside of the dashpanel under the ammeter. (doesn't matter, 6 or 12 volts, OEM 6 volt coil always requires the "infamous ballast resistor) Then the OEM 6 volt squarecan coil ALSO requires a 12 to 6 volt converting resistor. p/n 8NE10306 is a 12 to 6 volt converting resistor. ...BUT... you still need that "infamous ballast resistor" connected in series like flashlight batterys. It can go between your ignition key and 12/6 resistor or it can go between 12/6 resistor and frontmount squarecan coil. Understand? Oh year, new ceramic resistors ALWAYS SMOKE, don't worry, it'll disapear after about 30 minutes. You just saw it, cuz yer watching, and that is good. Junction box? usually call it junction BLOCK. it holds the "infamous ballast resistor" under the ammeter. p/n 8N12250. Hook the battery supply wire to the center terminal, and one wire of the ignition switch. The other ignition switch wire then connects to one side of the "infamous ballast resistor". The other side of the ballast resistor would normally go thru the sparkie tube to the top terminal of the squarecan ignition coil. Somewhere in that wiring line-up between the ignition ON switch wire and the 6 volt coil has to be the 12-6 volt converting resistor. Mount it where it can't melt plastic wire insulation. I'm gonna assume yer alternator is the popular common 3-terminal Delco 10-SI 12 volt alternator with built-in electronic voltage regulator. The common wiring scheme P-2 (remote sense) has short wire connected directly to the BIG BATT STUD at back of alterator. Then the P-1 (switched excite) "R" terminal? is connected thru a resistor to the ignition ON switch wire terminal block. There is the possiblility that your "R" terminal name is for the P-2 "remote sense" terminal. In which case, connect "R" with short wire to BIG BATT STUD output. And connect P-1 (switched excite) thru yer extra resistor to the igniton switch ON terminal. Understand? There are many ways to convert to 12 volts, some of 'em even work..... .....respectfully, Dell a 12 volt advocate for the right reasons That said, I haven't found the right reason for my eazy starting 6 volt 52 8N. And I know 8-ways to do it right the first time.
