ring gear bolts
robert
07-07-2004 11:32:43
I am sure this question has been ask before
whats the best way to remove the rivits from the case to take your ring gear off.?
and also where can you find the right bolts to put it back on .
Help
Robert
Dell (WA)
07-07-2004 12:28:34
 Re: ring gear bolts in reply to robert, 07-07-2004 11:32:43
Robert..... ..diffy ringgear rivets are best "drilled" out on drill press. Replacement bolts are available from your Ford/New Holland dealer. And they are the only source that I know about. Mite pricey tho..... ...Dell
Pitch
07-07-2004 14:31:24
 Re: Re: ring gear bolts in reply to Dell (WA), 07-07-2004 12:28:34
if I remember rightly there are thirteen of them at just under ten bucks apiece. That does not include the csatellated nuts or the pins.
