TIMING???
BOB
02-25-2001 12:11:24
IM REBUILDING A FUNK WITH A 226 FLATHEAD 6CYL. MY PROBLEM IS THE DIST SEEMS TO BE IN A TOOTH OFF BY THE WAY ALL THE PICTURES I SEE LOOK. HOW DO I FIND TDC WITH THIS TYPE OF ENGINE , ANY HELP WOULD BE HELPFUL
bg
02-25-2001 12:14:09
 Re: TIMING??? in reply to BOB, 02-25-2001 12:11:24
The same way you find TDC in any engine. Pop the plugs out and check for the compression stroke on #1 cylinder. When the piston reaches the top of the compression stroke, that's TDC. Eastwood makes a little whistler device to screw into the plug hole that lets you know when TDC comes up.
