no terminal block
8ngreenhorn
07-08-2004 17:11:33
I have an 8N mill on a 9N. I'm tryin to rewire the dang thang but I can't get spark. Turns over like a fool but that's it. I gots the manual but little knowledge of that electricity stuff. I do know I don't have a terminal block
Danny in CO
07-09-2004 08:05:38
 Re: no terminal block in reply to 8ngreenhorn, 07-08-2004 17:11:33
Greenhorn,
The terminal block is just a ceramic block with 3 posts on it that mounts on the back side of the dash. If your 8N engine has a front mount distributor, you will need a ballast resistor to keep from frying the coil. The ballast resistor mounts between 2 posts on the terminal block. These terminal blocks are readily available. Get one and mount it on the back side of the dash.
Good luck,
Danny
Russ in SoCal
07-08-2004 20:24:56
Side mount distributor or front mount?
Rob
07-08-2004 17:54:59
The terminal block is just a place to bring the wires together; assuming you don't have or need a resister.
The block can be replaced by two wire nuts. You need to bring 3 wires; one side of the ammeter, one side of the ignition switch, and the batt post of the voltage regulator into one wire nut, and 2 wires; the other side of the ignition switch and the coil wire, into the other wire nut.
Doing that, and all things being good, should get you a spark.
8ngreenhorn
07-08-2004 18:03:43
 Re: Re: no terminal block in reply to Rob, 07-08-2004 17:54:59
Thanks
Rob
07-08-2004 19:13:28
 Re: Re: Re: no terminal block in reply to 8ngreenhorn, 07-08-2004 18:03:43
You get around to it you probably need to get a terminal block just so you're one the same page with the book and people you talk to on the board and such.
