Jubilee project
Rick H. Ga.
07-08-2004 20:18:51
While disassembling the engine on the Jubilee project, I found a problem with the front oil seal/governor housing. Once I removed all the dirt and grime I noticed that the front of the governor cover/housing where the front oil seal goes was damaged/busted at some point in time. Looks like I will need another governor housing. Someone used some kind of epoxy or other resin to "glue" the front seal to the busted housing.
There is nothing wrong with "patching-up" or "riging" something to make it work but I don't really like to do things like that. I perfer to to do it right if possible. Some things are OK to patch up or rig but not the front engine oil seal. Other than that, the condition of the engine looks to be pretty good, although it does need an overhaul.
I look at it as another opportunity to fix something.:-) Rick H. Ga.
It ain't an old tractor..
07-08-2004 22:55:25
 Re: Jubilee project in reply to Rick H. Ga., 07-08-2004 20:18:51
'less it's part made out of JB Weld.
Rob N VA
07-08-2004 20:39:17
Got any pics?
