Order Ford 8N Parts Online
8N Starter Solenoid - Is it possible?
Rich in Michiga
07-09-2004 04:58:57
Well, I have determined that the starter solenoid is not an original 8N starter solenoid thanks to your description.
Previously, the tractor did not utilize the push button so I am wondering if it is possible that the starter solenoid is HOT activated versus ground activated?
If this is the case, would you suggest replacing it or would you just rewire it to accomodate a "hot" switch to the solenoid?
I wish I had thought of this last night when I was messing with the tractor but I didn't think of it until I was driving to work this morning.
Thanks again, I appreciate the support.
Rich
Dell (WA)
07-09-2004 08:19:53
 Re: 8N Starter Solenoid - Is it possible? in reply to Rich in Michigan, 07-09-2004 04:58:57
Rich..... ..there are several types of 4-terminal starter solenoids. Most take a switched volts to activate. Sometimes the 4th-terminal provides a by-passed volts to the ignition coil ballast resistor. Its hard to guess what kind of starter solenoid you have.
A real OEM 3-terminal tractor safety starter solenoid $10 (cheap) Mount it with the small center terminal against the engine so its hard to gittoo (don't ask)..... ....Dell
Rich in Michigan
07-09-2004 07:43:37
Jumper Cable across the solenoid?
A jumper cable across the solenoid should tell me if the solenoid is working, right?
Dan
07-09-2004 05:06:33
I have never heard of a hot activated solenoid, but then again - I am not as knowledgable on that as many here on the board. If it was my tractor, I would get the correct solenoid ($8) and wire it up to the starter button as designed. This way, you can save your brain cells remembering how you rigged it up in the future - or at least save the next owner from the same confusion.
Good luck,
Dan
txblu
07-09-2004 06:43:09
 Re: Re: 8N Starter Solenoid - Is it possible? in reply to Dan, 07-09-2004 05:06:33
Hot activated means that(after swtiching on the ignition switch) depressing the start switch places voltage on the solenoid vs ground activated that has voltage applied by the ignition switch and is activated by the depressing the grounding (safety) switch.
Both types are used with the grounding system used into the early '60's. Later the opposite was used but still incorporated the safety function of having to have the tranny in N before it'd kick over. (At least my tractors are that way.)
Mark
Dan
07-09-2004 08:18:54
 Re: Re: Re: 8N Starter Solenoid - Is it possible? in reply to txblu, 07-09-2004 06:43:09
Thanks, learn something new every day!
Dan
