6v vs 12 v
rbell
07-09-2004 05:25:16
OK lets settle this once and for all!
I have air in my back tires provided by a 12 volt compressor, while the air in my front tires was provided by a 6 volt compressor.
Which one will stay inflated the longest?
Tee Hee Tee Hee
robert
07-09-2004 16:12:58
 Re: 6v vs 12 v in reply to rbell, 07-09-2004 05:25:16
But then what happens if you use a 8V like I have beeen using O know now what.
Jack - Illinois
07-09-2004 14:45:06
Ifn 6 volt is positive ground and 12 volt is negative ground hadn't you outter use the 6 volter for taken it out and the 12 volt fur puttin it in?? Or maybe it depends ifn you gots the thing facing north or south - polarity you know!
some guy from texas
07-09-2004 06:12:52
Tried the N thing. Never could get the hang of it. Had to sell it. New lawn tractor won't start and they don't have a forum. Should I hit it with a six or 12 pound hammer and which will work the best on hard plastic?
Larry (MO)
07-09-2004 06:50:13
 Re: Re: 6v vs 12 v in reply to some guy from texas, 07-09-2004 06:12:52
Tex - they do have a lawn tractor forum if you click on the forum link in the upper left hand corner of the browser.
If you really want to destroy your tractor I have found that an open gas tank and a match works very well on hard plastic. Oh yeah - dont stand too close if you take this advice.
Jeb2N
07-09-2004 05:35:49
How about this: Use the engine operated tire pump...now which is better? The engine with a 6V system or the 12V? Gasoline on the fire
Jeb
Ron/PA
07-09-2004 06:15:21
 Re: Re: 6v vs 12 v in reply to Jeb2N, 07-09-2004 05:35:49
You guys just don't get it do ya? Yer still pumpin 12V air into them tires. Now around here we are lucky to have a few OLD, DEEP coal mines, and we run wayyy back in the bottom and get a load of 1948 6V air and it worked just fine, until a neighbor mentioned that we were pumping it into 1987 12V tires. No use looking for a resistor for that match, cause the rims are run by a couple of wild cat, magnetos and when ya put it all together, the whole tractor tends to roll downhill. I'm seriously thinking of swapping the whole mess off on a brand spanking new, Black & Decker 18V cordless 3 Wheel drive, with a side car and fender skirts. Ron
Joe (IN)
07-09-2004 16:40:40
 Re: Re: Re: 6v vs 12 v in reply to Ron/PA, 07-09-2004 06:15:21
Congratulations, Ron. That is the funniest damn thing I've heard this week! Thanks for making my day!
rbell
07-09-2004 09:22:04
OK Ron you win :-)
Best one yet
I Doubt it,
07-09-2004 09:28:08
 Re: Re: Re: Re: 6v vs 12 v in reply to rbell, 07-09-2004 09:22:04
Knowing this crew, once quittin time comes around I'll get a major whoopin from the true tellers of tall tales and then the real entertainment will begin! (GRIN) Ron
