Found the problem!!! - THANKS
Rich in Michiga
07-09-2004 13:49:54
I used a jumper cable from one end of the solenoid to the other on my 8N and she tried to turn over. I then decided to check to see if the solenoid is "hot" activated so I jumpered the hot lead to the middle post and again she tried to turn over.
I am going to replace the solenoid so it is set up as "typical" as you guys suggested to avoid my confusion in the future.
THANKS for all the help.
My next step after she starts is to figure out if the alternator needs some more wiring done.
