Order Ford 9N Parts Online
9N with a serious timing problem
John From Fernd
07-09-2004 22:35:55
My 9N die from an idle (I posted on this a couple of months ago and I still haven't got it resolved). I did a lot of dumb things like a carb rebuild (it needed it but that just throws another variable into the mix). I've got Dell's 3/16" spark with a snap. Everything seemed about right...still not starting. I even payed for a tractor mechanic to come out for a couple of hours to show me where I screwed up. What He found really has me confused.
When I'm on TDC (on #1 piston) between the compression and power stroke (made a tool to feel piston location) the rotor is almost exactly in the 12 o'clock position (0 or 360 degrees)between 4 and 1. I'd have thought it ought to be just about on #1's electrode pad on the cap, ~315 degrees (CW). Isn't this thing gear driven? How did it get 45 degrees out of time? The shaft through the distributor meshes correctly to the tractor and I'd have though if I had broken a tooth out of a gear such that the timing had slipped, I'd be able to feel something on the rotor when it turns over. Has anybody ever had something like this happen to them? Any ideas?
I'm afraid my next move is to pull the front end off to see if the timing marks on the gears line up (and I REALLY don't want to do that). They say the world is evolving into chaos and me pulling the front off would surely get us there faster. - John From Ferndale
Denny
07-13-2004 08:27:30
 Re: 9N with a serious timing problem in reply to John From Ferndale, 07-09-2004 22:35:55
Well John, I think I would have to go with Dell on this one, if you are having a tough time finding your timing problem, I would also suspect that your cam gear has slipped on it's center core, some of these gears were made with a bakelite or fiber center with a steel ring gear fitted or pressed on to them, unfourtnatly, the only way to know for sure, is to tear it down, but if everything else checks out ok, it might be worth the look, Good luck, Denny
John from Ferndale
07-13-2004 09:43:18
 Re: Re: 9N with a serious timing problem in reply to Denny, 07-13-2004 08:27:30
Thanks to all of you for you comments. I actually met Dell last weekend. What an interesting guy (and I have pictures of him)! I'm in the process of taking the little 9N apart right now. There were a couple of other symptoms that make sense now: we couldn't get any compression reading until we closed the throttle and when pulled, it tried to blow oil out of the air cleaner. This all makes sense if the intake valve is open during the compression stroke (well, I think it does anyway).
- John
Bob
07-09-2004 23:28:30
third party image
Look at this picture, and notice the crankshaft key at the 9:00 position as you're facing the front of the tractor, and the slot for the distributor drive is positioned vertically, and offset to the right, as viewed from the front of the tractor.
If you can get the center crank bolt out of your front pulley, and note visually that the key is at the 9:00 position, the distributor drive should be as pictured. (You may have to rotate the crankshaft 1 turn.) If the relationship between the keyway position and the distributor drive slot is precisely as pictured, you can rule out the timing gears being bad, and having slipped.
Dell (WA)
07-09-2004 23:05:51
John..... ...I'm gonna be at the Highland games in Mt Vernon this weekend (sat aft & sun morn) doing a bordercollie sheepdog trial. I'll be working in the sheeppen. I'll be wearing a white beard an cowboy hat and leaning on my shepherds crook. Stop by and we'll chitchat..... .Dell
Its quite possible that your pressed-on bake-lite camshaft gear has slipped on the end of the camshaft. It is NOT KEYED. Unfortunately, the only "cure" is a new 4-bolt camshaft and gear. I know of no way for amature mechanic to re-set the camshaft gear and correctly index it to the lobes. The only way you're gonnna find out is to remove the cylinderhead and front timeing gear cover and watch everything move..... ..Dell
John From Ferndale
07-15-2004 15:55:41
 Re: Re: 9N with a serious timing problem in reply to Dell (WA), 07-09-2004 23:05:51
Yep, Dell hit it right on the nose. The bake-lite gear with the aluminum insert is broke, not enough to be free-wheeling, just enough to screw up the timing.
Now I've got questions on how to get a replacement gear indexed. I see what looks like a machined key slot in the cam (or at least where the gear was bolted on) and kind of a matching key slot on the block behind it. Is that what you use to get the gear in the right quadrature (ie, align the two key slots and the mark on the gear should be in-line with the mark on the crank)?
Next question: Is the gasket that I screwed up between the front cover and the pan actually part of the entire pan gasket such that I'm going to have to take the pan off to replace the gasket when I button this thing back up?
And a question for the moderator: How do I embed a picture (jpg or whatever) in a post? I've got a dandy picture of when good gears go bad.
Thanks again to everyone who took the time to respond. I mentioned what an incredable support group this form is for the "tractor challanged" to a gal at work and now she is trying to get her boyfriend (who also has a tractor) to take a look at the site. Thank you Yesterdays Tractors.
- John
John From Ferndale
07-09-2004 23:24:38
Dell,
I've got commitments for Saturday (at least in the morning) but I'm going to try to make it down to Mt Vernon (where are they holding the Highland Games anyway?) I'd really like to meet you. I'm 6'-6", salt and pepper short beard, glasses, and not too bright look'n.
Pressed on and bake-lite, heck, I'm suprised it lasted this long. What 65 years, if I replace it, it won't have be replace again until my son is my age. - John
Dell (WA)
07-10-2004 05:56:09
 Re: Re: Re: 9N with a serious timing problem in reply to John From Ferndale, 07-09-2004 23:24:38
John..... ..Highland Games are at the Fairgrounds across the river from Mt. Vernon. Like I said, we'll be hanging around the sheeppen. You may have to pay entrance fee but watching the little girls dance around the swords is well worth it. (grin) Hope you can make it..... ..Dell
jt in IN
07-09-2004 22:44:21
Strange...
I found that exact same thing with my 8n.... just last night. I didn't have a tool, just my finger feelig for max compression, and a low battery turning it over. My rotor was *definitely* at 12 o'clock when my finger was being blown off the open spark plug hole. I tested again with #2, and it was at 9 oc'lock.
I've fought getting my tractor started for a month and finally, through a stroke of luck, replaced my coil today and she fired right up.
Hope you are as lucky,
jt
(who did a lot of unnecessary, but needed work on his tractor too)
John From Ferndale
07-09-2004 23:09:17
 Re: Re: 9N with a serious timing problem in reply to jt in IN, 07-09-2004 22:44:21
jt,
I did a new coil, mechanical advance, battery, starter switch (I pushed on it long enough to let the smoke out), and a full tune-up.
By the way, the tool is real handy. With a hacksaw, trim the crimped rim off the metal part of an old spark plug so you can pull the white guts out, replace it with a piece of a 5/8 oak dowel. Take a length of #12 AWG solid copper wire and spin it using a vice and drill until it is straight and rigid. Drill a hole through the center of the dowel so you can put the wire through it, bend it into a dogleg shape that will reach over the piston (it will take a couple of tries to get a shape you can get in the spark plug hole). You won't be able too feel much of the stroke but the air coming up around the wire in the hole will let you know it's a compression stroke and the wire will pop up at TDC. - John
