Order Ford 8N Parts Online
8n engine oil
Sam
07-10-2004 14:15:10
does anyone know what oil weight to use with the 8n?
B. Jones
07-10-2004 18:20:51
 Re: 8n engine oil in reply to Sam, 07-10-2004 14:15:10
I use 15-40 in the summer time and it is a very high quality oil and easy to get. You can get it at Walmart. I also use it in my Diesel Ford tractor and both are holding good oil pressure ( 20-40 psi hot). I also think that a straight 30 wt. would work ok also. Just don't let anyone talk you into using NON-detergent oil in that good old tractor. Many over the road truckers use 15-40 in their rigs. I think it is good stuff. B. Jones
Rob
07-10-2004 15:24:43
Warmer weather you'll probably need 40W or even 50W to keep some oil pressure. Lighter oil in the winter.
Try to keep 15psi-20psi oil pressure. Lot of N's running with 5psi.
Robert
07-11-2004 20:00:59
 Re: Re: 8n engine oil in reply to Rob, 07-10-2004 15:24:43
I don't use anything but 30 hd
winter or summer I never have any problems
all the manuals say to use 30
Bob , Pa
