Order Ford 8N Parts Online
8N CLUTCH STUCK
randy
07-11-2004 09:20:54
I HAVE AN 8N 48 49 WITH FRONT LOADER THAT I DROVE JUST FINE I THEN PARKED IT FOR A MONTH AND THE CLUTCH IS STUCK. I HAVE TRIED TO DRIVE UP HILLS IN HIGH GEAR, PUSH IN TO TREE THE ONLY WAY I CAN USE THE TRACTOR IS TO JAMM IN GEAR. HELP PLEASE
Rob
07-11-2004 10:04:19
 Re: 8N CLUTCH STUCK in reply to randy, 07-11-2004 09:20:54
First, block down the clutch.
You might take something to pry with against the rear wheel and rock the tractor as hard as you can. If it won't rock loose than leave it overnight or for a day or two...all with the clutch block down.
Won't hurt to step out the door and cuss at it every once in awhile, too.
They say those plates get sticky when the tranny leaks on em. You have fluid leaking out that weep hole? The one with the cotter key? Just curious.
CSavage
07-12-2004 23:00:12
 Re: Re: 8N CLUTCH STUCK in reply to Rob, 07-11-2004 10:04:19
When mine stuck, after trying everything short of breaking it in half, I drilled a hole in the bellhousing area about where I thought the clutch disk would be. I already had the clutch pedal tied down. I just barely touched the clutch disk with a screwdriver and it popped free from the flywheel. My 8N is a working tractor so I don't mind the hole, but it could be easily plugged.
