Dell - Thanks - New Distributor Oil Question
Rick
07-12-2004 04:11:43
Dell: After you answered my question about the need to lubricate a new side-mount distributor, I went out and examined my new distributor more closely. I discovered that it actually does contain a lubrication port - a new type. The new one contains a flush opening that houses a small steal ball that, evidently, is under the pressure of a small spring - like a grease fitting. I gave it a couple of squirts from my oil can. Thanks again for your help.
JWM
07-12-2004 18:15:26
 Re: Dell - Thanks - New Distributor Oil Question in reply to Rick, 07-12-2004 04:11:43
Talking about side-mount distributor--Does front mount ever need lubrication and if so how do you do it? Thanks
Dell (WA)
07-12-2004 05:29:04
Rick..... ...glad you found your oiler for your sidemount distributor. The flip-cap is standard. The squeeze-ball is a later development. Both work, ya just haffta ocassionally, giv'em a shot of engine oil to keep the "wick-wet"..... ..Dell
premie-farmer
07-12-2004 10:46:41
 Re: Re: Dell - Thanks - New Distributor Oil Questi in reply to Dell (WA), 07-12-2004 05:29:04
So that's what that little thingy is, I was wonderin what that was for. Guess I need to give it a squirt since I know it hasn't received one in the year I've owned the O gurl.
souNdguy
07-12-2004 06:32:34
Hey Dell... since i may be getting a 5000 soon.. how about you get one too.. so you can teach me some hints and tricks on it !
(thought you might get a good laugh out of that..)
Soundguy
Hobo, NC
07-12-2004 04:40:24
on mine i removed what ya have now and installed the cup type. what ya have is ok but i wanted the cup. removed the ball deal and the cup fitting fit the dist. housing
