Order Ford 8N Parts Online
Need someone to rebuild my 8n motor
Rick Rivera
07-12-2004 14:39:33
Looking for someone in the southern California area that can rebuild my 8n Ford Tractor Motor.
Its smoking and has no compression. Please qauote me a price.
Thanks Rick
Fast Ed Ohio
07-12-2004 23:03:00
 Re: Need someone to rebuild my 8n motor in reply to Rick Rivera, 07-12-2004 14:39:33
Ive never been able to start a gas engine with no compression to see how bad it smokes . I understand there is a lot of that whacky tabacky stuff in so . Cal . Just my opinion . ( I think Rick is pulling or leg ) .
Bruce (VA)
07-12-2004 17:53:10
The complete parts kit (sleeves, pistons, bearings, rings, valves, etc) is about $450 from TISCO. If you take the engine to the shop, you will probably save $100. If the crank needs to be turned, add the $100 back. Labor around here in VA will run $400-$500. So....in VA, figure $900-$1000. I'll be intrested to see what rebuilds cost elsewhere!
Ed S. (IL)
07-13-2004 09:57:55
 Re: Re: Need someone to rebuild my 8n motor in reply to Bruce (VA), 07-12-2004 17:53:10
I used a fellow near me (Central IL) who specializes in restoring antique engines, and paid a premium for the work. Given the problems he found and corrected (that I would certainly have missed, not having the tools and equipment to mic everything out), I think it was probably worth it (but it's gonna really hurt the checkbook for a while!).
The machinework total was right at $1500... plus about $500 for the parts (ouch). About $400 of the machining cost was having him do the rebuild and paint the engine (it will be a few months before I reassemble the tractor and I didn't want it to start rusting again).
That doesn't include the next $500 I'm going to have to spend to clean, prep and paint the tractor (well, now that the engine is pristine, I HAVE to, right?)...
I'll still be out less than a used Kubota would have cost me... and having more fun, too!
es
