I have never built a barn, garage, or even a shed. That said, a couple of things do occur to me with regards to shop buildings in general. I don't like trusses too much. There's a lot of space lost in a truss. I'd rather have the use of a second floor, even if the footprint is smaller then the floor below it. I know trusses are a very good way of building a wide cover supported only on the ends. I personally just don't like the space overhead that is eaten up by the trusses themselves. I've worked in shops that were essentially pole barns, and it wasn't that big a deal working around the poles. Built well, the spaces between the poles were the size of a decent garage space. No matter how big the shop or garage, you're going to want bigger. So I'd try to build in such a way that future expansion is possible. I do like this aspect with the miracle-span. It would be simple enough to extend the building in the future. I personally think I like gambrel construction. It's not cheap, but it seems like the best of both worlds to me. You gain a loft, you don't have trusses, and you can have an open shop floor below. They also look pretty to me. What can I say, I don't like ugly buildings, even if they are effective. The engineer in me looks at the miracle-span and sees that the strength is coming from the depth of the V's, and the metal gage. I can't put any values to them because I don't know what they are. The wider the building though, the deeper those v's would have to be to hold up to the same snow a narrower span could take. Judging purely from the pricing scale, it seems that this point has been addressed; the wider spans are much more expensive. This would indicate to me that the metal is heavier and probably deeper v'd. This type of construction is also extremely sensitive to the footing. Probably more so then just about any other type of construction. Again, this is the engineer in me looking at it, it is not based on any direct experience. Regardless, the engineer in me thinks the footing would be critical (double emphasize, underline, italicize). I can't figure out what I think of the height of the miracle-span buildings though. At 12-15 feet, it is taller then what I would need for virtually everything I own, but too low for a second story or loft. Seems like quite a bit of wasted or lost overhead space. Around here, Morton buildings are worshiped as the holy grail of steel buildings. I have no idea if they are or not. In any case, they are darn expensive.
