Rob, You forgot to mention the cost of the special oversize pistons. Any idea what they cost? It would be interesting to see what the cost of the boring, the pistons, and the rings would actually be, to go that route. Even if he decides to bore his sleeves, he will be fitting new oversize pistons to his connecting rods, so the wrist pin bushing issue will be the same as if he goes to a new set of standard sleeves and pistons. The complete piston, ring and sleeve set from THIS site is $179.00. For American made parts, that's tough to beat! Installing the sleeves is an easy DIY job, so he should be able to do it himself, and save spending extra $$$ there. {{{{{{{{Sleeve & Piston Set - Complete sleeve & piston set for Ford gas tractors 2N, 8N, 9N (1939-1952) with 120 CID, 4 Cylinder, Gas, Flat Head Engines. Made in USA. Contains: sleeves, pistons, piston pins & retainers and rings. When ordering, specify in 'Comments' section of order form: #1. 3 or 4 Ring Pistons; #2. Sleeve Thickness (.040 or .090). Made in USA (Made in the U.S.A.) (Part No: 8N-PK) $179.00}}}}}}}}
