worn cam in sidemount dist.
RB(VA)
07-16-2004 13:28:54
how do you remove the old cam and weights from a sidemount dist.?
I have one lobe worn down about .008 from the other three lobes.
Any suggestions appreciated.
Roy
RB(VA)
07-16-2004 14:12:13
 Re: Re: worn cam in sidemount dist. in reply to STUMP PULLER (TX), 07-16-2004 14:03:45
Hey, thanks for the fast reply.
I just replaced the dist. bushing, trying to remove the play, then I found that part of the problem was the worn lobe.
Apparently I've never seen the snap ring, the only thing that I was aware of was the spring on the top end of the shaft that held the rotor on.
I'll go have another look.
thanks again. Roy
