I have a background in asbestos as I work for a school district and it is highly regulated. As Mr. Sherman says, it is also highly overracted to. Asbestos only poses a problem when airborne and breathed in. In that state, it can be deadly. It most commonly was a problem in insulation workers and particularly in the marine industry. That being said, it is most dangerous when it is friable--that is when you can crush it under finger pressure into a fine powder and it can become airborne. There are a great number of protocols for dealing with asbestos. First if it is siding or floor tile or the like, deal with it whole. Just don't grind it to make dust. If you have fiber, fluff, or powder insulation, wet it. When the fibers are wet, they can't go airborne. Bag it in plastic along with anything that it may be on. Don't use a shop vac to vacuum dry asbestos, it is so fine it will go right through the filter and shoot through the air. If you work on any amount you should minimally have a respirator suitable for asbestos. Paper masks don't do a thing, again asbestos is so fine it shoots right through them. This is not meant to be recommendations or directions of how to do anything, just an opinion (disclaimer here for lawyers). I assume no responsiblity for any methodology that may be implied by the above, but hope it gives a little sense about this stuff. By the way, the ceramic fiber replacement insulation, which is not regulated, works well because it looks a lot like asbestos. What do you figure that will happen with that stuff in 10 or 20 years. JU
