Timing on front mount distributor
Aaron
07-20-2004 17:16:00
How do I adjust the timing on a front mount distributor. there is no slots in the bolt holes on the distributor mount like a side mount on my 861. So how do I change the timing or check it?
(PICTURE) Ken N Tx
07-21-2004 13:29:58
 Re: Timing on front mount distributor in reply to Aaron, 07-20-2004 17:16:00
third party image
Aaron
07-21-2004 17:49:49
 Re: Re: Timing on front mount distributor in reply to (PICTURE) Ken N Tx, 07-21-2004 13:29:58
I can't thank you enough Ken. This is just the information I needed.
ZANE
07-21-2004 04:33:45
There is a screw or cap screw on the left side of the distributor housing that retains a retangular washer thingy. This sits in a slot and you can adjust the ignition timing by loosening the screw and pushing up or down on the screw to move the distributor plate inside the distributor.
If the flywheel was installed correctly on some models of the N tractor there should be timing marks on the edge of the flywheel wheel that can be seen through a small hole in the clutch housing on the right side of the tractor. Make sure that the #1 cylinder is on Top dead center of the compression stroke and then see if the timing marks are visible through the hole in the clutch housing. If it is then I would mark the degrees that you want to time it to with a white pen or white paint etc.
If you don't have a timing light then just loosen the timing screw on the distributor side and start the engine and while it is running move it up or down until you hear the engine sounding right. If when you try to start the engine and it tries to kick back the starter then you have it a little too early on the ignition and you should move the screw down a little and try it again.
If it sounds like the engine is beginning to load the you are too far late with the ignitiona and the screw needs to be moved up a bit until the engine stop sounding like it is laboring.
I have never put a timing light on an N engine. Good ear or bad thinking????? ? Works for me for the past 50 years or so. Guess it works!
Zane
Jeb2N
07-20-2004 19:18:48
You have to remove the distributor to time it. take the two bolts out and set it on your workbench. The tang that sticks out is offset where it fits into the camshaft gear and you have to measure the distance between it and one of the bolt hole centers. This is hard to describe but is clearly outlined in the F0-4 manual. There is a screw and a plate with notches on it on one side of the distributor that will effectively adjust the timing if you have to adjust it to meet specs.
Aaron
07-21-2004 02:57:17
 Re: Re: Timing on front mount distributor in reply to Jeb2N, 07-20-2004 19:18:48
Thanks for the info, Jeb.
