Order Ford 8N Parts Online
8n amp meter
pslade
07-21-2004 12:48:11
I needed to replace the amp meter in my 1950 8n. The only ones available are the post or conection poll type. How is it wired? Thanks
Gary B.
07-22-2004 10:50:19
 Re: 8n amp meter in reply to pslade, 07-21-2004 12:48:11
If you have no other use for it, I'd like to get that old meter from you. I'll make it worth your while.
Gary
pslade
07-22-2004 12:27:40
 Re: Re: 8n amp meter in reply to Gary B., 07-22-2004 10:50:19
I'm sorry but the old one had be broken beyond repair. If I still have it I will make it avaiable to you
Bruce (VA)
07-21-2004 13:07:07
Cut the wire, put wire ends on both ends & connect them to the new meter. If it reads a constant discharge, reverse the wires.
pslade
07-21-2004 13:49:07
 Re: Re: 8n amp meter in reply to Bruce (VA), 07-21-2004 13:07:07
Thank you...
JohnMDJCMMEMM@NETZERO.COM
07-21-2004 17:57:02
 Re: Re: Re: 8n amp meter in reply to pslade, 07-21-2004 13:49:07
You can also disconnect the wire from the junction block, connect it to one side of the amp meter and make a jumper to go from the amp meter to the junction block. This way you preserve the old wire in case you ever find a replacement induction meter.
Rob
07-22-2004 13:26:40
 Re: Re: Re: Re: 8n amp meter in reply to JohnMDJCMMEMM@NETZERO.COM, 07-21-2004 17:57:02
I guess you have NetZero for an internet service provider. Good price, the service any good?
JohnMD
07-22-2004 13:30:31
 Re: Re: Re: Re: Re: 8n amp meter in reply to Rob, 07-22-2004 13:26:40
Netzero is OK for $14.95/month. If I keep messing up and posting my e-mail address I'll need to change.
