how to swap from 19'' rims to 16''
9n adrian
07-23-2004 14:41:42
My tires on my 9n are getting really bad. I would love to switch to 16 inch rims and tires but not sure how. If I get some do they just bolt right up like the 19's.
Bus Driver
07-23-2004 18:51:55
 Re: how to swap from 19'' rims to 16'' in reply to 9n adrian, 07-23-2004 14:41:42
On a Ferguson TO-20, the front hubs from Ford cars 1940-1948 would fit on the spindles. But those are not so plentiful now as in the late 50's- early 60's. I assume that some of the Ford tractors would have matching spindles to the cars.
Jimmyjack
07-23-2004 17:03:38
I have a pair of extra 16 inch rims to fit an 8N if you cant find any.
Brad
07-23-2004 15:31:26
I just checked into this and was told that I would only need to replace the front hubs and wheels. Our tractor should be the same setup as yours right now.
Brad
1945 2N
Bruce (VA)
07-23-2004 15:35:49
 Re: Re: how to swap from 19'' rims to 16'' in reply to Brad, 07-23-2004 15:31:26
He does not need hubs if he finds 9N 16 inch rims. If he can't find them & wants to use the more common 8N 16 inch rims, then he will need to put 8N hubs on his 9N.
Brad
07-23-2004 15:52:07
 Re: Re: Re: how to swap from 19'' rims to 16'' in reply to Bruce (VA), 07-23-2004 15:35:49
I would bet those are rather difficult to find!
Brad
Bob
07-23-2004 16:18:53
 Re: Re: Re: Re: how to swap from 19'' rims to 16'' in reply to Brad, 07-23-2004 15:52:07
I think wheels from a 1936 or 37 Ford car will interchange with the 9N, if you can find them. We had an 8N with 4.00 X 19 tires. My uncle had an identical tractor with 6.00 X 16s. I think there is less backlash through the steering wheel with the 19" tires. They are also relatively inexpensive.
SteveB(wi)
07-23-2004 21:51:45
 Re: Re: Re: Re: Re: how to swap from 19'' rims to in reply to Bob, 07-23-2004 16:18:53
Car rims will not fit 9N hubs, different bolt circle. But the car hubs will fit on the tractor allowing car rims to be used.
Bob
07-24-2004 11:10:52
 Re: Re: Re: Re: Re: Re: how to swap from 19'' rims in reply to SteveB(wi), 07-23-2004 21:51:45
I have to disagree with you. Ford used an odd wheel with a large bolt circle for two years on their cars. I am quite sure that is what the 9N front hub is derived from.
Bruce (VA)
07-23-2004 15:28:40
Yes; just make sure you get 9N 16 inch rims. An 8N 16 inch rim will not work on a 9N unless it has 8N hubs. Your 9N wheels have the lug nuts almost on the far outside of the rim, whereas the 8N rims have the lug nuts very close to the hub.
9n adrian
07-23-2004 15:59:58
 Re: Re: how to swap from 19'' rims to 16'' in reply to Bruce (VA), 07-23-2004 15:28:40
thx for the info... gotta go find some 16" rims for my 9n now.
2n1943
12-02-2004 10:00:33
 Re: Re: Re: how to swap from 19'' rims to 16'' in reply to 9n adrian, 07-23-2004 15:59:58
I"ve been researching this and stubled onto this discussion. It looks like 36-37 ford 16 inch car rims may fit, but I have not measured the bolt circle yet.
