Order Ford 9N Parts Online
Another 9N Generator
9N 89716
07-27-2004 05:31:08
Quick question - single pole, 3 brush generator, am getting continuity from the pole to the generator case. Is the pole supposed to be insulated from the case? If so, this is probably where my non charging problem is coming from. Thanks
Rob
07-27-2004 05:55:29
 Re: Another 9N Generator in reply to 9N 89716, 07-27-2004 05:31:08
If the generator is assembled I believe you'll get continuity but it's not necessarily because of insulation failure. You will be reading through the brush and windings. Looks like you have to lift the brush from the rotor to check for a short to ground.
Dell (WA)
07-27-2004 05:52:57
Unless you have "Lab-Grade" ohm meter, you will read what looks like a "short" from the 1-terminal 3rd brush 9N genny to ground. Its NOT a short because the other side of the armature and field goes to ground inside the gennny barrel. It has to, to complete the circuit. Its ohmic value should be 1.5 ohm.
But to answer your question, yes, the single termial output should and MUST be insulated from the metal barrel of the genny..... ...Dell
Jim Cox
07-28-2004 06:55:33
 Re: Re: Another 9N Generator in reply to Dell (WA), 07-27-2004 05:52:57
Dell, you sure know your stuff. Consider this a compliment.
Jim Cox
9N 89716
07-27-2004 06:13:31
OK. Makes sense. I'll disconnect the wire from the pole, and check the output voltage @ 3/4 throttle, and go from there. Appreciate the help.
Rob
07-27-2004 09:43:55
 Re: Re: Re: Another 9N Generator in reply to 9N 89716, 07-27-2004 06:13:31
You should be able to vary the volts by moving that screw on the end. If you can change the volts that way it must be working.
