Ford Engine Block Question
Rusty
07-28-2004 17:31:13
I have a used engine to replace the bust block on my jubilee. The used engine has no sleeves but the same bore as the busted one from the jubilee. Can ya'll tell me what engine block without sleeves fit the jubilee? Or will it fit the jubilee? Thanks for your ford knowlede.
ZANE
07-28-2004 19:05:17
 Re: Ford Engine Block Question in reply to Rusty, 07-28-2004 17:31:13
If it is the same bore as the one with the sleeves then you should be able to bore and sleeve the used one to standard size.
Does the used engine have a place on the block for a fuel pump????? If so it is an industrial engine but still may fit the NAA.
Zane
txblu
07-29-2004 06:43:49
 Re: Re: Ford Engine Block Question in reply to ZANE, 07-28-2004 19:05:17
Don't know when Ford quit sleeving ag engines. I redid a 172 gas a couple of years ago and it had several shades of paint and no ID so I don't know if it was 800,900, or 4000 but it was 172 and no sleeves.
Mark
