hydro fluid
8ngreenhorn
08-02-2004 03:07:11
I changed my hydro fluid to 80/90w and only put in about three gallons before it poured out the overflow (?) hole. Perhaps I put it in too fast before it made it throughout...? The capacity is abot 4.75 gallons, right?
Jeb2N
08-02-2004 03:50:19
 Re: hydro fluid in reply to 8ngreenhorn, 08-02-2004 03:07:11
About 4.75 gal is correct. Did you remember to drain all 3 drain plugs? 1-pipe plug under rear end, 2-cast iron hex plug under hydraulic pump, 3-cast iron hex plug under transmission. If you missed any of these, then you didn't get all of the old fluid out. That's probably where the extra fluid came in.
