help
Robert
08-02-2004 08:57:23
Has anyone ever had to remove the bolt from the radius rod and the axle extension whats the best way to remove mine must be siezed bad.
Robert,Pa
Ramon
08-03-2004 11:16:50
 Re: help in reply to Robert, 08-02-2004 08:57:23
I have said it before, but put a bottle jack under the bolt and raise up on it to take the weight of the tractor. THEN from the top beat DOWN on the axle and/or the radius rod. I don't work well upside down!
Rob
08-02-2004 12:04:29
Yeah, back the nut off to where the end of the bolt isn't exposed and wail on the nut with something like a 3# drilling hammer. It'll move. You can put torque on it while you hit it helps some. Hitting up from underneath will wear me out pretty quick though.
Russ in SoCal
08-02-2004 19:53:43
 Simple in reply to Rob, 08-02-2004 12:04:29
Put one end of a kid's teeter-totter under it. Then smack DOWN on the other end. Oh, and take the kids off first.
Rob
08-03-2004 07:11:08
 Re: Simple in reply to Russ in SoCal, 08-02-2004 19:53:43
You use toys to work on your tractor?
Odd, but then you are California.
Russ in SoCal
08-03-2004 10:04:23
 Re: Simple in reply to Rob, 08-03-2004 07:11:08
Rob,
If yer referrin' to stuff I have fun workin' with, Yup, several thousand dollars worth.
Russ
Rob
08-03-2004 10:36:34
 Re: Simple in reply to Russ in SoCal, 08-03-2004 10:04:23
Never heard of anyone paying thousands for a teeter totter for working on the tractor.
SteveB(wi)
08-02-2004 11:32:10
Also unbolt the radius rod on the transmission side to release any tension.
Eric ATL
08-02-2004 09:50:49
If you haven't done it already, use some Kroil or PB Blaster penetrating oil first. Hope to help, Eric
MikeT
08-02-2004 09:19:30
Do you have a large cast iron "C" clamp? Get a 1" thick board and drill a hole in it and place the board over the bolt head. Tighten the C clamp while pecking on the bottom. Might use another board on the bottom of the bolt to prevent damage to the threads.
After you get it out clean up the hole with sandpaper on a dowel rod and an electric drill.
