Ford 4000 Question????
8-N Nut
08-02-2004 18:38:38
Will the early model 4000 manual transmission, swap out with a later model 4000 selecto-speed transmission? They look real close to me! Thanks, guys!
Ramon
08-03-2004 11:03:51
 Re: Ford 4000 Question???? in reply to 8-N Nut, 08-02-2004 18:38:38
I could aanswer that if you were a bit more specific as to what you mean by "early" and "late" model. Generally any 1963/64 will work on any other 1963/64 and any post 1965 transmission should work on any other post 1965 as long as you stay in the same "family." In the past I have swapped out both the 800 series SOS units and the 3000/4000 SOS units. Biggest issue was setting up the conventional clutch, as I recall. I would split & remove the SOS, bolt up the standard transmission to the rear axle, and work from there.
8-N Nut
08-03-2004 19:32:01
 Re: Ford 4000 Question???? in reply to Ramon, 08-03-2004 11:03:51
Very informative answer! Thanks so much!
