Naa:clutch engaged will not release
Randee Peel
02-28-2001 06:07:30
There are numerous messages on the bulletin board regarding clutchs that will not disengage because of rust buildup. I have never had a problem until this year and it has occurred twice. Two soutions are recommended and I am wondering if these solutions cause additonal problems.
1. Tie down the clutch pedal when not in use. Will this cause problems if over extended periods of time?
2. Remove the starter and spray something like WD40 onto the clutch plate. Will this cause problems with the clutch?
Thanks
Frank from Maine
02-28-2001 08:35:37
 Re: naa:clutch engaged will not release in reply to Randee Peel, 02-28-2001 06:07:30
Get yerself a nice piece of 2by6 and block yer clutch down...have been doin' it fer years cos my 49n sits for weeks on end between usin' it. Hasn't seemed to cause any problems yet.
peterc
02-28-2001 07:02:46
I would not hesitate to tie the pedal down but I wouldn't spray any lubricant on the clutch disk. best thing overall is to start it up every week or so. the less a machine sits the better it works. just my opinion.
