Flywheel question
ozbo
08-05-2004 07:18:01
Ring gear was bad on original flywheel out of 8n I'm rebuilding. Had a second flywheel from parts pile with good ring gear, but clutch side of flywheel is pitted in several spots some as deep as 4-5 thousands. Is this going to cause a problem with clutch grab or undue wear on clutch plate? Thanks for your advice.
Hal@NC
08-05-2004 09:18:24
 Re: Flywheel question in reply to ozbo, 08-05-2004 07:18:01
New one is only about $17.00.
ozbo
08-05-2004 11:22:57
 Re: Flywheel question in reply to Hal@NC, 08-05-2004 09:18:24
Whut???
ozbo
08-06-2004 10:47:25
 Re: Flywheel question in reply to Hal@NC, 08-05-2004 12:28:20
Problem is not the ring gear; problem is pitting on the flywheel.
don b
08-06-2004 13:47:26
 Re: Flywheel question in reply to ozbo, 08-06-2004 10:47:25
I have a good one if you can't clear yours up without taking too much off,email me if interested. don
Hobo, NC
08-05-2004 07:54:08
If the bolts that hold the pressure plate on have a shoulder make sure they do not bottom out before they tighen the cover down. Lay the pressure plate on the flywheel and check. Do not use a air wrench on these bolts. If they do hit the shoulder or botton out you can add a washer.
Bob
08-05-2004 07:21:33
Have the flywheel resurfaced, if you want to use it.
