Bert..... .using 12 volts on a 6 volt starter solenoid for the short time it takes to start your 12 volt converted tractor does not burn up the solenoid and neather does 12 volts on a 6 volt starter harm it for the short time it takes to start your tractor. HOWSOMEVER.....if you go constantly cranking for over a couple of minutes, your going to make your starter puke its guts all over its commutator. Same thing for your starter solenoid. Iffn it takes more than 10 seconds to 12 volt start your tractor, you got real problems, fix 'em. The reason a 4 terminal solenoid doesn't work, is one side of your tractor type solenoid coil is internally connected to the battery terminal and the other side of the coil is externally grounded by the starter switch at the tranny. Generally speaking, solenoids don't care positive or negative ground. Starters don't care positive or negative ground. But both don't like to be abused by excessive use of higher than designed voltage, its just that generally, you can get away with it for the short time it takes to start before they get too hot. The NH parts guy is correct. The Advance guy is only correct if you keep the solenoid in long time use, which you won't if your engine starts like it should. Myself, I'd go ahead and use a standard 6 volt Ford starter solenoid..... ..Dell
