pulling capacity
8ngreenhorn
08-09-2004 03:16:08
Got a bush hog at auction Saturday for $100. Good shape with heavy steel. One wheel. Must weigh about 350 to 400 lbs. I don't suspect it'll be a problem, but what is the pulling capacity of an 8N with good compression?
souNdguy
08-09-2004 05:43:50
 Re: pulling capacity in reply to 8ngreenhorn, 08-09-2004 03:16:08
Ditto what Mike said. These N's pull a 5' cutter pretty well. Get an over running coupler for safety, so when you hit the clutch/brakes, the mower doesn't push you along.
Soundguy
Mike S
08-09-2004 03:51:14
Lifting capacity is probably close to 800lbs right at the tractor. Pulling is another thing. On level ground, I can pull my 4000lb boat. Will go up a small incline pretty easily. But not recommended as the brakes on these old tractors just ain"t that good to stop something that heavy at any speed above walking. Your tractor will handle it fine. I am assuming that it is a 5 foot one as they appear to be the most common.
