Order Ford 9N Parts Online
Thought I had a 9n govenor on my 9n but?????????
al
08-12-2004 10:10:11
Can someone explain or show me the difference between the NAA govenor and the govenor off a 9n? On my 9n when I disassembled the govenor I found that it has 3/4" balls instead of 5/8" balls. Is this a govenor off a NAA? What exactly is a NAA? Now the kit I bought is wrong, the lower race as a radial bearing on it instead of a thrust bearing and it won't work in my assembly. What is the part number for the correct assembly for my govenor? Please help!
don b
08-14-2004 06:42:12
 Re: Thought I had a 9n govenor on my 9n but??????? in reply to al, 08-12-2004 10:10:11
The 9n-2n and 8n gov. is the same except the 9n and 2n has 3 arms and the 8n has 2.Internal parts are the same.Naa gov. will not work on 8-9ns. don b
Dell (WA)
08-12-2004 19:25:15
Al..... ....the N-Governor has (4 ea) 5/8" balls, the NAA governor has (6 ea) 3/4" balls. It is quite possible that the previous owner/shadetree mechanic might have subsituted larger balls to make-up for worn governor races, instead of rebuilding it correctly. You never know. The complete NAA's governor is NOT INTERCHANGEABLE with the flathead N's governor..... ...Dell
souNdguy
08-12-2004 12:14:31
Looking thru the archives.. it looks like there were different aftermarket gov's available that fit the N engine.
Also, Is your 9n engine oem.. or is it an industrial unit?
Soundguy
Bruce (VA)
08-12-2004 12:06:16
You could have the balls from a NAA. The part number for the N balls is 358081-S, and the part number for the NAA balls is 18229. The NAA governor will not fit an N.
Steve W (NY)
08-12-2004 11:52:09
I'm not 100% sure, but I believe a Jubilee has an overhead valve engine, completely different from your 9N. Did you buy the wrong kit?
Take Care
Steve
souNdguy
08-12-2004 11:27:49
third party image
An NAA is the 1953/1954 sucessor of the 8n.. it was dubbed the 'golden jubilee' for 1953 for fords aniversery.. It is also the last of the single tractor series years.. and last 'N' tractor.. hundred series was 1955 and up..
Here's a pic of my 54 NAA
Soundguy
