Order Ford 8N Parts Online
8N center housing in a 2N
Geo
08-13-2004 10:10:14
I recently purchased a 2N to use as a loader. When I got time to try the 3 pt hitch, I found it wouldn't work. When I popped the right side inspection plate, I was greated with red paint and a 8N hydraulic pump. I pulled the lift cover and verified that it was a 8N center. When the previous owner replaced the housing he just put the old 2N complete liftcover assembly back on and let the fork hang down.
My question is can I hook the 2N controls to the 8N hydraulic pump?
souNdguy
08-13-2004 15:31:45
 Re: 8N center housing in a 2N in reply to Geo, 08-13-2004 10:10:14
Like jeb said.. the 8n pump and top cover will fat and work in a 2n housing.. BUT.. ya got to have them paired.. same for the 2n pump and lift cover.. if paired they will work in the 8n housing.. just can't swap 8n pump with 2n lift cover or 2n pump with 8n lift cover..
Soundguy
Jeb2N
08-13-2004 10:13:25
Nope. The 8N lift cover and pump are paired. Same thing with the 9N/2N. I think you might be cheaper to replace the lift cover as opposed to swapping out the pump. But yeah, that'll definately cause the hitch to not work!
2ntom
08-14-2004 03:42:54
 Good in reply to Jeb2N, 08-13-2004 10:13:25
You can have a 2N with a 8N swinging drawbar!
