Order Ford 9N Parts Online
9N governor
9N 89716
08-13-2004 13:25:48
My governor has started leaking oil at the mounting face, Quick question - when I take the governor apart, will anything come flying apart ( anything under spring pressure or tension)? Thanks for the help
J.D.Redwine
08-13-2004 18:05:04
 Re: 9N governor in reply to 9N 89716, 08-13-2004 13:25:48
You might want to pull it apart and check, the bearings may be starting to eat through the case.
Rob
08-13-2004 14:23:43
 Nope. Go for it. in reply to 9N 89716, 08-13-2004 13:25:48
It comes off the tractor in one piece. You could hold it there in one hand, run a 1/16" bead of RTV, slap it back on, torqued the bolts to 10ft/lbs, and you're good to go. You'll be fine.
Joe (IN)
08-13-2004 19:18:17
 Re: Nope. Go for it. in reply to Rob, 08-13-2004 14:23:43
Better yet, treat the problem and not the symptom. The housing is probably warped from being overtightened. Pull the governor off and remove the small set screw that you"ll find on the face next to the gear. Grasp the gear and pull the guts out of the housing and set them aside. Get a fresh sheet of 100 grit sandpaper, lay it on a flat, true piece of steel, and lap the face of the housing until it"s flat again. Reasseble and put her back on with a fresh gasket. If you"re patient and lap it true, it"ll cure the leak every time.
9N 89716
08-13-2004 14:39:37
Thanks for the info. thats what I was thinking, just don't like surprises.
Ken N Tx
08-13-2004 13:51:02
Check out this site for rebuilding the gov..
9N 89716
08-13-2004 14:40:53
 Re: 9N governor in reply to Ken N Tx, 08-13-2004 13:51:02
Thanks for the link. May need it once I take it apart.
