Headlight Wiring clips
2ntom
08-14-2004 06:37:46
third party image
Hello, How are these headlight clips, part #358297-S2, attached to the hood?
Dan
08-15-2004 02:39:08
 Re: Headlight Wiring clips in reply to 2ntom, 08-14-2004 06:37:46
2ntom - find the area on the inside hood ridge (support) running down the length of the hood that you want to attach the wiring to, this support is a couple inches from the bottom of the hood on the inside. You can see this support by opening the battery door on the top of the hood and looking to the bottom edge of the hood. The "hump" on the end of the clip is the top, and the spiked part goes to the bottom. Push the wiring into the clip first and get it to the inside loop of the clip. Then push the clip onto the inside hood support ridge by slightly angling the clip down, then push it onto the support. The top hump should apply pressure so the spiked section bites into the metal slightly to keep it from wiggling off. These work great and I use about 3-4 on the side the wire runs dowm, and one on the other side of the hood just before it clips into the headlight pigtail.
Good luck,
Dan
