Order Ford 8N Parts Online
Rear hub locknut on 8N
RB
08-15-2004 03:20:49
The locknut on my 8N is comming loose. I noticed a bunch of holes through the nut and some divets into the threaded part of the splined hub shaft. What exactly did Ford use here? Can I use some Locktite to hold the nut?
ZANE
08-15-2004 19:20:42
 Re: Rear hub locknut on 8N in reply to RB, 08-15-2004 03:20:49
A MAN OF GERMAN DECENT INVENTED A NUT TO REPAIR AN 8N AXLE THAT THE THREADS HAVE BEEN DAMAGED OR STRIPPED OFF.
THE MAN’S NAME WAS SWAGGART AND HE LIVED SOMEWHERE IN NORTH ALABAMA. THIS WAS ABOUT THE TIME I STARTED WORKING ON FORD TRACTORS IN LATE 1959 FULL TIME. BEFORE THAT I HAD BEEN A SHADE TREE MECHANIC AND AIRCRAFT ENGINE MECHANIC.
I ALSO RAN THE PARTS DEPARTMENT AT THE SMALL FORD TRACTOR DEALERSHIP THAT MY BROTHER IN LAW OWNED AND OPERATED WITH MY HELP.
ALL WE EVER CALLED THIS NUT AS A SWAGGART NUT AND I SOLD THEM AT THE RATE OF ABOUT 6 A WEEK SOMETIMES. I USED THEM TOO IN THE SHOP TO SAVE THE FARMERS A BUNDLE ON DODGING HAVING TO BUY A NEW AXLE.
THE NUT IS ACTUALLY TWO NUTS. ONE HAS A REGULAR AXLE FINE THREAD AND THEN ABOUT TWO THIRDS OF THE HEX PORTION OF THE NUT HAS A TAPERED PIPE THEAD AND IS SEGMENTED IN SIX PLACES ON THE PIPE THREADED PORTION OF THE NUT WITH ANOTHER NUT THAT THREADS ONTO THIS TAPERED PIPE THREADED PORTION. WHEN THE FINE THREADED PORTION IS TIGHTENED ON THE AXLE UNTIL IT IS SNUG AGAINST THE HUB OF THE AXLE THE OUTER NUT IS TIGHTENED UNTIL IT BEGINS TO SQUEEZE THE TAPERED OUTSIDE THREADS DOWN ON THE SHAFT. THEN YOU CAN CATCH BOTH OF THE HEX PARTS AT THE SAME TIME AND TORQUE IT ON DOWN. IF IT TRYS TO SLIP ON THE BAD AXLE THREADS YOU CAN TIGHTEN DOWN ON THE OUTER NUT SOME MORE. USUALLY IT WILL DO THE TRICK AND SAVE BUYING A NEW AXLE IF IT IS JUST THE THREADED PART THAT IS BAD.
ZANE
Steve IA
08-15-2004 04:16:57
There is a snap ring that holds the nut in place. pn# 8N 4187. Less than $1.00 IIRC. Available at your local parts store or online. Tighten nut to 450 ft/lbs. install ring. Nut won't go anywhere. Steve 8N I69302
clearfield
08-17-2004 19:40:08
 Re: Rear hub locknut on 8N in reply to Steve IA, 08-15-2004 04:16:57
Some place in one of the many 8N tractor web pages I remember seeing a nut that you use when your threads are damaged but I can"t remember where I say it does anyone know ??
also how are you to torq this baby up to that torq specs. can you rent a torq wrench that torq that much ???
Clearfield
