tube vale stem
8ngreenhorn
08-16-2004 03:28:37
A rear tube stem, brass, had a coupler, which held another stem, in which the valve itself is contained. The coupler is broken, so the secondary stem with the valve, is free. TSC didnt have what I need. Do I have to replace the tube, and is that as tough as a job as I"d guess?
Ramon - the old man
08-16-2004 07:04:47
 Re: tube vale stem in reply to 8ngreenhorn, 08-16-2004 03:28:37
Often if there is calcium (fluid) in the tire you will have a problem with getting a replacement valve stem patch to stick. Also, while a non fluid tire is easier to repair, be ready to pay a good deal more than $25 to repair a tire with calcium in it.
souNdguy
08-16-2004 06:13:35
While this advice is right on... those extenders are available. I'm surprised TSC didn't have them.. try a napa.. in the big truck section.
Soundguy
Dell (WA)
08-16-2004 04:55:17
Greenhorn..... ...new rear tire tube is $25 (installed). Just haul your tire into the tire shop. Iff'n you want, you can pay for a service call and the tractor tire shop will come to your place for service.
CAUTION: your rear tire tube may be filled with corrosive Calcium Chloride water solution. CaCl acts as anti-freeze and is a cheap way to add 350 lbs weight for additional traction for plowing. Iff'n yer not plowing, you don't need the additional weight..... ...Dell
Leroy
08-16-2004 04:34:56
A good tire shop can cut off the complete old valve stem and replace it, new ones go on like a patch
Steve IA
08-16-2004 04:31:42
Check your local tractor tire fixit place. They'll know. Steve 8N 169302
