ORC
9N 89716
08-18-2004 09:27:35
Probably a dumb question, but I am asking because I don't know. My ORC has what appears to be a place to screw in a grease fitting. I have no info on the clutch, or the mower it is attached to. Am I to assume that I should grease the ORC? Thanks
Fessman
08-18-2004 15:47:27
 Re: ORC in reply to 9N 89716, 08-18-2004 09:27:35
The grease fitting size is 1/8"NPT. The instructions that came with the ORC advise to lube it everytime it is used, and it is not possible to overlube.
Fessman
Jeb2N
08-18-2004 09:43:52
Yes, you do want to keep the ORC lubricated. Usually the grease zerk hides the rollpin that keeps that sucker from coming off. Keeping it lubed will ensure that the ratchet portions works smoothly and won't lockup after years of use.
