Order Ford 8N Parts Online
Governer control 8N
RB
08-20-2004 12:07:10
How can you tell if your Governer is in need of an overhaul? I have no tack on my tractor so rpm"s not possible to see. When the tractor is under load (eg) climbing a hill with a mower, it seems to take forever to recover to the upper rpm"s...is this normal?? I noticed my linkages are worn out a bit, it takes about 1/3 throttle to engage the govener lever. Any thoughts?? Thks Ron
Bruce (VA)
08-20-2004 12:29:44
 Re: Governer control 8N in reply to RB, 08-20-2004 12:07:10
The easiest test is to see if the engine responds to throttle changes in the lower half of the throttle lever quadrant. Put the lever at it's lowest point; the engine should be at idle, 400-500 rpms. Then, start moving it up a notch at a time. Is the engine speed increasing? If not, from my personal experience & contrary to what the manual will tell you, just go ahead & pull the governor off the tractor & open it up. There are other tests & adjustments you can fool with, but you might be spending a couple of hours trying to adjust a worn out governor. You have an oil line, two pieces of linkage, and two bolts and it's off the tractor. Take the screw out & inspect the races & balls. If the balls have flat spots & the races have grooves, you will need to replace them. Once the inside of the governor is in spec, then you can start adjusting the linkage & control spring. Remember the first rule of governor repair: SHORT bolt on TOP!
