Govenor Linkages How to set up?
RB
08-20-2004 14:46:08
My linkages are very sloppy is this normal? Does anyone have a technical link to show proper set up? Thanks Ron.
Bruce (VA)
08-20-2004 16:42:21
 Re: Govenor Linkages How to set up? in reply to RB, 08-20-2004 14:46:08
The ends are spring loaded; as the spring tension lessens with age, the linkage will loosen as it attaches to the governor & the carb. The short linkage between the governor & the carb on my 50 sidemount is new, and it does not move a bit; the throttle rod linkage has more play in it because of the worn out spring. My thinking is that when it falls off the governor or the carb, it's time to replace it. Otherwise, you can take up the slack due to wear by adjusting it. Sorry, but I'm technology challenged & can't post a picture. The I&T manual does have some decent linkage pictures on pages 42 & 43 that might be helpful.
